| Piston damage | |
+102strokeman fullgazlolo Adco zeze Apriliabarth fpayart crigar carlovitch1 Frits Overmars Döllinger 14 participants |
Döllinger
Nombre de messages : 102 Localisation : Biblis Date d'inscription : 14/01/2017
| Sujet: Piston damage Mer 3 Oct 2018 - 20:24 | |
| Hallo, i just finished the MAICO MD 250. A bit different to my TZ and Rotax 256. Frits helped me with the scavanging angles, the combustion chamber layout and the ignition timing. Thank you for your great advices The most important thing: Frit's consulting was very good. The engine has more power than the clutch can take. I have to increase the spring power. But while trying different carburettor jettings the engine suddenly blocked. Piston seizure... The engine was warm but not hot, throttle ca. 3/4 open, 7000rpm. Mixure 1:25 ELF 909 with 100% AVGAS. Spark plug was brown, normal, piston top wet with oil. The cylinder size is 76,00mm Piston 75,94mm. It is a "Wahl" piston, forged. What do you think is the reason for that seizure? Is 0,06mm play too less? Could the piston material be a wrong type? The engine was not in stress, just a normal test ride. No campare with a race. Except that the engine ran with only little vibration, ouput power ect. very well. [Vous devez être inscrit et connecté pour voir cette image]I´m looking forward for your suggestions. Best regards, Bernd |
| Sujet: Re: Piston damage Jeu 4 Oct 2018 - 0:12 | |
| I'm glad that you found the power you were looking for, Bernd. Throttle 3/4 open can be dangerous: even when the main jet is large enough, the needle jet can cause a lean mixture. And why use AvGas? It's costly, its energy density is modest, it's slow-burning and it brings more heat into the engine than regular E98 fuel.
0,06 mm clearance for a 76 mm diameter piston is a minimum; 0,07 mm would be safer. And of course the piston material could be the wrong type, but without more detailed information that remains just a guess.
However, the pictures of the seized piston make me suspect something else: its conicity. Those 0,06 or 0,07 mm clearance is measured at the biggest diameter of the piston. But higher up, were the piston gets hotter, you'll need more clearance, which means that you will need a barrel-shaped or conical piston. How much conicity? That is a matter of experience, which you are gathering right now. But do not be afraid to go beyond 0,2 mm top diameter clearance. |
carlovitch1
Nombre de messages : 1040 Age : 57 Localisation : Pays Catalan Date d'inscription : 20/05/2018
| Sujet: Re: Piston damage Jeu 4 Oct 2018 - 13:17 | |
| I can only agree with Frits. I suppose your cylinder is with an iron sleeve and not any kind of plating. This combined with a forged piston (my experience is that for some reason it has a tad more dilatation than cast pistons) makes that you need to be on the safe side with your clearance. |
| Sujet: Re: Piston damage Jeu 4 Oct 2018 - 15:08 | |
| D'un autre côté, pour ne pas être "agree" avec Frits dans ce domaine il faut des arguments bien au-delà du mécanicien lambda ! |
carlovitch1
| Sujet: Re: Piston damage Jeu 4 Oct 2018 - 16:42 | |
| Loin de moi l'idée que je puisse rivaliser avec Frits dans ce domaine. C'était juste pour signaler à notre préparateur de Maico, ce qui n'avait pas été abordé, que l'association piston forgé+cylindre chemisé fonte doit être maniée avec précaution, j'ai quelque expérience sur ce sujet particulier. |
| Sujet: Re: Piston damage Jeu 4 Oct 2018 - 17:30 | |
| Peut-être ai-je mal formulé, et désolé si j'ai pu t'offusquer. C'était simplement une révérence envers le maître et pas du tout une escarmouche quelconque entre toi et moi ! |
| Sujet: Re: Piston damage Jeu 4 Oct 2018 - 17:49 | |
| Il faudrait être sûr que ce soit une chemise fonte, les photo peuvent indiquer le contraire C'est par-contre un cylindre refroidi à l'air donc plus chaud. 0.06 de jeu, pour un diamètre de 76 mm cela me parait trop peu. Pour un piston forgé et une chemise fonte, je mettrais volontiers 0.09 à 0.1 mm. Un peu moins pour un revêtement Nikasil. La disposition des traces de serrage semblent indiquer un manque de jeu, surtout en tête. Il est clair que faire des test à mi-ouverture ça n'aide pas. il suffit que l'aiguille soit mal adaptée au puits et c'est la catastrophe. It should be sure that it is a cast shirt, the photos may indicate the opposite On the other hand, i t's a air cooled cylinder, so warmer.0.06 clearance, for a 76 mm diameter, it seems to me, too little.For a forged piston and a cast iron sleave, I would gladly put 0.09 to 0.1 mm.A little less for a Nikasil coating.The arrangement of the seizing marks seems to indicate a lack of clearance, especially at the head.It's clear that doing mid-opening tests, does not help.It is enough that the needle is badly adapted to the tube, and it is the catastrophe. |
carlovitch1
| Sujet: Re: Piston damage Jeu 4 Oct 2018 - 18:49 | |
| - crigar a écrit:
- Peut-être ai-je mal formulé, et désolé si j'ai pu t'offusquer. C'était simplement une révérence envers le maître et pas du tout une escarmouche quelconque entre toi et moi !
Tu n'as pas à t'excuser car il n'y a pas d'offense, j'ai juste voulu expliquer plus clairement mon intervention. Apparemment, je serais peut-être à côté de la plaque car en y regardant de plus près, je crois que fpayard a raison, ça ressemble plus à un nickasil. Je pensais que les vieux Maico à air (en tous cas ceux que j'ai connu, 400 et 490 cross) avaient tous des chemises fonte. |
Nombre de messages : 4123 Age : 53 Localisation : cherbourg Date d'inscription : 07/02/2010
| Sujet: Re: Piston damage Jeu 4 Oct 2018 - 19:02 | |
| Interesting bike . AS far as I know there was the Maico MD 250 and the MD 250 WK.
Is your Maico a road bike or a racing bike ?
Another detail I wonder about that bike is how did the admission works ? |
| Sujet: Re: Piston damage Jeu 4 Oct 2018 - 19:13 | |
| - crigar a écrit:
- D'un autre côté, pour ne pas être "agree" avec Frits dans ce domaine il faut des arguments bien au-delà du mécanicien lambda ! ....... C'était simplement une révérence envers le maître et pas du tout une escarmouche quelconque entre toi et moi !
That is very kind of you, Crigar. But nobody should ever hesitate to disagree with something I say. If we would all agree on everything, none of us would learn anything . |
zeze
Nombre de messages : 253 Localisation : nogent sur marne Date d'inscription : 05/10/2010
| Sujet: piston damage Jeu 4 Oct 2018 - 19:59 | |
| Je confirme pour base 250 Maico MD cylindre Nikasil Mahle d'origine.Mais grosse difficulté pour acheter piston neuf........Grand merci a tous les contributeurs de ce genial forum. PS: Tiens Tiens un nouvel avatar pour Francis P........cela semble me rappeler quelle que chose.......... |
Döllinger
| Sujet: Re: Piston damage Jeu 4 Oct 2018 - 23:07 | |
| Hi,
@ Frits: the conicity is about 0,2mm. I have to measere that exactely tomorrow. Too much work today. Thanks for your thoughts! I use AVGAS in all my engines,normally 1/3 to 2/3 100 Octane fuel. It´s easy to get for me, all other drivers use it, so it´s easy to compare jetting ect. And I´m used to the jetting with it. It makes a good spark plug face. But E98 it´s an interesting thing to test next time on the Dyno. What do you think are the advantages?
The cylinder is nicasil coated, original it was chrome.
@ F. Payart: The piston is a forged one. I know that a mid range test is not very usefull. But due to an heavy accident I´m not abled to drive the bike myself at the moment. So i don´t have a direct opportinity to react properly on the bike.
At the moment a needle jet DQ268 is fitted. I will get a little more rich.
@ Apriliabarth:
It´s my father's bike. I built it up this year from zero. He was always into these bikes. It´s a pure racing machine.
Tomorrow i will meet the manufaturer of the piston. He´s the opinion he can tell me the reason of the seazure within 5 minutes. I`m curious for that conversation. It´s not my intention to blame him, I just want a solution for this problem for the future.
Best regards,
Bernd
| Sujet: Re: Piston damage Ven 5 Oct 2018 - 0:36 | |
| "At the moment a needle jet DQ268 is fitted."
With which needle Nbr? |
Döllinger
| Sujet: Re: Piston damage Ven 5 Oct 2018 - 8:16 | |
Nombre de messages : 6084 Localisation : Limoges Date d'inscription : 19/02/2016
| Sujet: Re: Piston damage Ven 5 Oct 2018 - 19:14 | |
| Très intéressant ce problème de conicité. Je pense que c’est à surveiller quant on adapte des pistons de moteurs à refroidissement liquide dans des cylindres à air,sans doute aussi en 4 temps. |
| Sujet: Re: Piston damage Ven 5 Oct 2018 - 21:15 | |
| - zeze a écrit:
- Je confirme pour base 250 Maico MD cylindre Nikasil Mahle d'origine.Mais grosse difficulté pour acheter piston neuf........Grand merci a tous les contributeurs de ce genial forum. PS: Tiens Tiens un nouvel avatar pour Francis P........cela semble me rappeler quelle que chose..........
Ca ne peut pas te rappeler quelque chose... ça l'annonce!!! |
Döllinger
| Sujet: Re: Piston damage Dim 7 Oct 2018 - 17:13 | |
| Hallo, I visited Helmut Wahl on friday. He is the senior and in his late 70s. A nice man, easy to talk with. He looked on the piston and guessed it was a problem with the cylinder coating. But he was not really sure. It´s a strange kind of damage he said. It was a Powerseal coating. Powerseal coated all my cylinders for Rotax 256 and TZ 350 since several years without any problems. He honed off the damaged coating parts, milled off 1/10mm on the top of the skirt.(botton is still 75,94mm) and lathed some oil grooves into the piston. And he recommened a coater in Ditzingen near Stuttgart. This should work together. He did not blame any lubrication, ignition ect. He just said that he would assemble the top end bearing with a needle cage with smaller needles. I will do so. Due to this i have no choise. The cylinder will be recoated and i try to run the engine with the modified piston. When it`s OK i take a new piston with the actual measerments. When not we will meet again. What do you think about it? Best regards, Bernd PS: My assumption: As the cylinder gets hot the material of the "wall" above the exhaust is pushing into the cylinder. When the piston is fitted with too less play it seizes. A good friend of mine got these problems with own casted TZ 350 7 port cylinders. I got these cylinders too but reversed the water flow direction and fitted a very large radiator. He took away some material of the seized parts of the piston and it worked. [Vous devez être inscrit et connecté pour voir cette image] |
Döllinger
| Sujet: Re: Piston damage Dim 18 Nov 2018 - 9:47 | |
| Hallo, the cylinder is now back from coating and i made a new test drive. This time the engine survived but still got good power. I changed: Piston diameter was decreased at the level of the ring, fitted a small end bearing with 4-6/1000mm more play, ended the ignition curve on a 20° straight instead of curvature to 9° to get the heat out at high revs (due to a 76mm bore), fitted a DQ 270 instead of the 268 (with K52) The engine did about 70km the first 40-50 with a rich mix. When I´m sure the engine will stand i can get leaner and pull the plug to a more agressive ignition timing. No edges can be felt on the cylinder but i have little concern about the "polished" areas above the outlet port. I never had problems like this with my watercooled engines. What do you think? Should i hone the cylinder again now, as it´s run in? [Vous devez être inscrit et connecté pour voir cette image]Here my father with the nearly ready bike. With fairing ready to run 89Kg. [Vous devez être inscrit et connecté pour voir cette image] |
| Sujet: Re: Piston damage Dim 18 Nov 2018 - 10:56 | |
| Hello
What is the ring (segment) clearance ? |
Döllinger
| Sujet: Re: Piston damage Dim 18 Nov 2018 - 11:47 | |
| The clearance is 0,25-0,3mm Tendentially more 0,25mm. |
| Sujet: Re: Piston damage Dim 18 Nov 2018 - 18:33 | |
| Sujet: Re: Piston damage Dim 18 Nov 2018 - 23:50 | |
| - 2strokeman a écrit:
- What is the ring (segment) clearance ?
Good question! - Döllinger a écrit:
- The clearance is 0,25-0,3mm Tendentially more 0,25mm.
That is very tight. I consider a ring gap of 0,5 % of the bore as a minimum for safety. And you need to make sure that the ring groove is deep enough radially. The ring must be able to lie a little (0,05 mm is enough) below the local piston surface. |
Döllinger
| Sujet: Re: Piston damage Lun 19 Nov 2018 - 9:34 | |
| Hallo Frits, today i measeured the ring gap accurately to 0,28mm. I will file a bit on each side of the gap to get to 0,38mm, what you see as a minimum. And the groove is deep enought, the ring can disappear in the piston. Thank you again for your knowledge. One can ask whatever for, you have a profund answer for sure! Your day seems to have more that 24 hours. Best regards, Bernd [Vous devez être inscrit et connecté pour voir cette image] |
Al mach
| Sujet: Re: Piston damage Mer 5 Déc 2018 - 4:57 | |
| Not connected with seizure, but what a poor casting quality! Many oil pockets: good thing for lubrication (I'm joking) |
wos
Nombre de messages : 16 Localisation : Germany Date d'inscription : 05/04/2018
| Sujet: Re: Piston damage Dim 23 Déc 2018 - 14:09 | |
- Hallo,
Here my father with the nearly ready bike. With fairing ready to run 89Kg. [Vous devez être inscrit et connecté pour voir cette image] If i understood frits "zündungs manual" Ignition advance should be lowerd for a cooler running of the cylinder! Think 20 degree is to much. ..that will produce a stay of more heat in the cylinder and cool down exhaust gas... 13- 15 degree at maximum revs would be better frits? Dankeschön! Grüße Wolfgang |
| Sujet: Re: Piston damage | |
| Piston damage | |
