| [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) | |
+85genna900 nikinn33 C_Wolf bentou maccas rgvbaz mattology Emmanuel Laurentz uniflow Ken Seeber yeahhim Al mach bengui ettoiffi teriks 2005bully mj43 husaberger Jeram Larry Wiechman vespafiend Muciek Polo les gazs t0nix Gordon Jones nine-thirtysix Filandro p12palof michaelten CRECY diskvalve Stephane Manuel Rainer pfpraider Forgi Tomi Paul Olesen senso romeuh80 Ölsau MINGRET01 pierre95 julien #41 ridley SB07 Blommen Ronath el castor mxer dutch fisher d.Bonnot eric² roost dcracing1 RAW Vagelis morini155 Piquer Ian Harrison Jarno Areomyst XpTpSMTT fpayart Institute of TwoStrokes fab evospeed Seb4LO Toop Mic wax jfn2 Hemeyla cristogrr melvyn trevor Brian Callahan Daniel A. Haufen Jan Thiel GtG001 Sabijator Marc rgdavid GrahamB koenich Frits Overmars Howard Gifford 89 participants |
Vagelis
Nombre de messages : 30 Localisation : Greece Date d'inscription : 09/07/2011
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Lun 5 Nov 2012 - 2:42 | |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Lun 5 Nov 2012 - 3:09 | |
| - Jan Thiel a écrit:
Plating and replating was always done by the same factory, called Tecnol.
I guess this one, Jan? [Vous devez être inscrit et connecté pour voir ce lien] |
Jan Thiel
Nombre de messages : 517 Age : 83 Localisation : Bangkok Date d'inscription : 12/10/2010
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Lun 5 Nov 2012 - 3:20 | |
| So MAPE has bought Tecnol. I did not know this! MAPE makes crankshafts. |
Jan Thiel
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Lun 5 Nov 2012 - 3:25 | |
| - romeuh80 a écrit:
- Hi
Can somoene post a photo of one RSA or RSW piston upside down? Sorry, I do not have foto's
The reason is, does the botton of the piston squirt match the cylinder squirt at bdc? No
The botton of piston squirt is rounded or just knife edge like the pistons I have on the table?
Should't this improve flow? It is knife edged. Of course I tried a round edge, thinking it would improve flow. But HP diminished a little bit! |
romeuh80
Nombre de messages : 102 Age : 34 Localisation : Leiria, Portugal Date d'inscription : 15/10/2011
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Lun 5 Nov 2012 - 3:45 | |
It seemed logical that at leats does not affect power, but diminished!?.... Experience says it all...
Thanks
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Lun 5 Nov 2012 - 15:33 | |
We tried from 40C to 90C, every 5C more caused 0,5HP power loss! Jan, I can't find it anywhere but you find an optimum water temp to run at? Did I read/remember it correctly the RSA water pump is 130l/m, the ideal was lots of water moving rapidly ? Was a thermostat used? Found today 10deg increase in water temp cost about 2-2.5HP |
Daniel A.
Nombre de messages : 55 Localisation : Germany Date d'inscription : 20/02/2012
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mar 6 Nov 2012 - 19:38 | |
| @ Howard Gifford, Frits Overmars & el castor I've got a little question regarding the Brisk spark plugs. Which do you now think should one choose best for a 2 stroke engine? Howard seems to have used an Iridium plug (without real improvements), while el castor used a Multi Spark Plug ("ZS" designation) that seems to give good improvements. What I am wondering about, because the big "head" of such a plug theoretically throws a "shadow" where burnt gases are hard to flush away (I hope you can understand how it is meant) Brisk offers so many different kinds of plugs that I don't look right through |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mar 6 Nov 2012 - 20:26 | |
| I can't say because I did not test them, Daniel. Ask Jan Schäffer of Langtuning. |
romeuh80
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mar 6 Nov 2012 - 22:32 | |
| Hi everyone. I have some questions about exhaust systems.
Usually exhaust midsection is a continuos section, it's internal diamenter is constant. But the Aprilia RSA exhaust, as posted on this thread earlier has no straight forward midsection, instead there is 2 small sections diverging from 117 to 125.5 and 125.5 to 127.8.
This means that straigh forward midsection is a compromise? It's strange how the Honda Pipe is mutch more simple and had not changed mutch over the years (the recomended changes in exhaust of 96' Honda RS125 are very near from the one frits posted).
Should higher compression ratio engine get a bigger midsection diameter? Or ajusting the timing correct's the problem? If you could understand how I am thinking.
Thanks
Vagelis
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mer 7 Nov 2012 - 0:00 | |
| Mr Frits has said that both the midsection and the 2-stage baffle are "relics" from an older design philosophy. And that a straight belly/single stage baffle would work just as well, given there is time for testing & finding the best dimensions.
I cannot help you with the belly Dia, because I don't know. I think of it as a medium of fine-tuning the pipe volume, its length and the baffle cone's angle; not a 'real' pipe part. Thus, I believe it's not directly connected to Comp ratio or timing -as is stinger nozzle for example. Higher Comp might reduce the EGT a little, 'lengthening' the pipe, while retarding the timing will do the opposite. Again, belly Dia seems irrelevant -better wait for Frits to correct me though. |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mer 7 Nov 2012 - 1:20 | |
| It's not irrelevant, Vagelis. but it's not critical either. |
Jan Thiel
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mer 7 Nov 2012 - 3:53 | |
Found today 10deg increase in water temp cost about 2-2.5HP No, a thermostat was never used. On the dyno the lower the temperature, the more HP! I do not know the lower limit, if something 'strange' happens if you go too low. But at a certain piont you might get fuel evaporation problems. At Aprilia HP still improved going from 45° to 40°. And at Bultaco I used tap water for cooling, about 20°, with good results and without any problem. Lots of water moving rapidly was clearly the best. Some people believe cooling the exhaust duct 'too much' would cost power. This proved to be nonsense. The more we cooled the more HP! Reducing wall thickness also proved to improve HP. The limit is mechanical reliability. Which makes me think that fixing the cylinder to the crankcase at its bottom is all wrong! The combustion forces should not stress the cylinder!
SB07
Nombre de messages : 52 Age : 44 Localisation : Goito (MN) Italy Date d'inscription : 05/12/2010
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mer 7 Nov 2012 - 9:07 | |
No, a thermostat was never used. On the dyno the lower the temperature, the more HP! I do not know the lower limit, if something 'strange' happens if you go too low. But at a certain piont you might get fuel evaporation problems. At Aprilia HP still improved going from 45° to 40°. And at Bultaco I used tap water for cooling, about 20°, with good results and without any problem. Lots of water moving rapidly was clearly the best. Some people believe cooling the exhaust duct 'too much' would cost power. This proved to be nonsense. The more we cooled the more HP! Reducing wall thickness also proved to improve HP. The limit is mechanical reliability. Which makes me think that fixing the cylinder to the crankcase at its bottom is all wrong! The combustion forces should not stress the cylinder! Mr Jan, what do you mean with "Reducing wall thickness also proved to improve HP"??? i did not understand??? This is my cylinder section ... I designed with a thickness of 7 mm ... I was wrong? [img] [Vous devez être inscrit et connecté pour voir cette image][/img] |
Jan Thiel
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mer 7 Nov 2012 - 9:19 | |
| Stefano,
Compliments with your very nice design! I just meant to say that reducing wall thickness improved power. And especially in the hottest places of course. Like the top of the cylinder, and around the exhaust duct. The limit, of course, is mechanical strength. And, in your case, maybe cooling capacity!
SB07
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mer 7 Nov 2012 - 9:39 | |
- Stefan,
Compliments with your very nice design! I just meant to say that reducing wall thickness improved power. And especially in the hottest places of course. Like the top of the cylinder, and around the exhaust duct. The limit, of course, is mechanical strength. And, in your case, maybe cooling capacity! Hello Jan I am Stefano Brutti ... your facebook friend! In this project, I can decrease the thickness with a milling cutter in small steps... by water flow... |
Jan Thiel
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mer 7 Nov 2012 - 10:06 | |
| Yes, I know who you are Stefano!
Try reducing the thickness and to test the power afterwards! But take care of deformation! |
SB07
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mer 7 Nov 2012 - 10:16 | |
Howard Gifford
Nombre de messages : 140 Age : 68 Localisation : Ottawa Canada Date d'inscription : 01/05/2012
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mer 7 Nov 2012 - 16:52 | |
| We have sucessfully tested coolant temperatures as low as 50 degrees F (10C) on the dyno . Colder than this seems to cause a misfire with our race fuel possibly from incomplete vaporization and we run the risk of what we call a "cold seizure" caused by the piston heating up and expanding faster than the cylinder. Our fuel is 116 octane r+m/2. The difference between 10C and 50C coolant temperatures is around 4HP The difference from 10C to 80C is 8HP on our 440 cc motor so you can see there is a big advantage to having lots of cooling. We also have the advantage of racing in winter temperatures that dip to -30C at times and we cool our race sled with ice so it is easy to keep it cool, however under sustained running the coolant out of the motor temperature stabilizes at around 80F (26.6C) . We run an auxillary electric pump to boost the flow and also cool the motor down to below 10C whenever there is a restart. One of our problems is that we have difficulty starting the motor cold if the coolant temperature gets below -10C. We have a handy "squirt bottle " with regular 87 octane that helps us start a real cold motor otherwise we keep the race sled inside a heated trailer. My advise is cool the motor as much as you can and run as much water through the motor as possible. There is no such thing as "overcooling" in summer weather temperatures. |
Howard Gifford
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mer 7 Nov 2012 - 17:14 | |
| I think what Frits is saying (correct me if I am wrong)is that it is more important to optimize the shapes and lengths of the cones to match your motor requirements than worry about the center section diameter. The center section (belly) is needed to attach the two cones together and time the reflected wave and the diameter is derived from the design of the cones. Larger center sections mean more agressive cone designs which usually have more top power but give up powerband and are used with high BMEP engines. I suspect the designer of Tubo-120 wanted a longer , more agressive reflected wave therefore he designed the baffle cone larger and the result was a slightly tapered mid section. However two stroke exhaust design is still progressing through empherical testing (although not at the level that Aprillia did with the RSA). Successful designs are then analyzed and reverse engineered to come up with math equations to explain why they work. Math only derived designs usually flop! |
romeuh80
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mer 7 Nov 2012 - 18:04 | |
| This is news overhere, I always thought that cylinder temperature would have an Ideal... 60º to 80º.
pfpraider
Nombre de messages : 16 Localisation : bourne england Date d'inscription : 25/11/2010
romeuh80
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Mer 7 Nov 2012 - 20:26 | |
| - Howard Gifford a écrit:
- I suspect the designer of Tubo-120 wanted a longer , more agressive reflected wave therefore he designed the baffle cone larger and the result was a slightly tapered mid section.
Good guess, I think |
Sabijator
Nombre de messages : 12 Age : 40 Localisation : Croatia, Trogir Date d'inscription : 01/07/2011
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Jeu 8 Nov 2012 - 2:08 | |
| Hi everyone On this RSA piston picture red arrows shows the material which is hardening piston around pin, does it affect mixture flow under the piston into the transfers when it goes down to BDC. The same question is for blue colored piston edge, would it be better for the flow to transfers if that edge is lower to the same layer as the piston pin material, and is it better for mixture suction into crankcase that all transfer ports and boost port are opened when piston goes up to TDC. [Vous devez être inscrit et connecté pour voir cette image]Second picture shows different piston design in that area which could be also weaker. [Vous devez être inscrit et connecté pour voir cette image] |
Jan Thiel
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Jeu 8 Nov 2012 - 3:24 | |
| The second picture shows a forged piston. We had forged and cast pistons. Cast pistons gave slightly more power. So the interior design of he piston seems to have little influence on HP. |
Paul Olesen
Nombre de messages : 59 Age : 35 Localisation : Milwaukee, WI USA Date d'inscription : 22/05/2012
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) Jeu 8 Nov 2012 - 20:34 | |
| While we're on the subject of coolant systems could those of you that know a thing or two about coolant system design please critique mine? Anything I should do differently? I've tried to follow the RSA as closely as possible. Cylinder is 79.7mm bore to put things in perspective. Thanks for any help. [Vous devez être inscrit et connecté pour voir cette image] |
| Sujet: Re: [GP125] All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars (PART 2) (Locked) | |
